noisy pipes after using hot water tap
8 May 2006
Cardiff
HI, I HAVE RECENTLY REPLACED A BATH AND SINK IN THE BATH ROOM, WHILST MAKING SOME OTHER CHANGES I ALSO DRILLED THROUGH A RADIATOR PIPE UNDER THE FLOORBOARDS, ALL HAS BEEN REPAIRED AND BLED THE RADIATORS BUT NOW, EVERYTIME WE USE THE HOT WATER TAP A LOUD HUMMING/VIBRATING SOUND IS HEARD FROM THE PIPES ( COLD WATER PIPE I'M SURE
) AND IT ONLY STOPS WHEN THE COLD WATER TAP IS LEFT TO RUN FOR A WHILE. ANY IDEAS ONHOW TO SOLVE THIS ??? :D
Put a few more pipe clips on it.
Oh and STOP SHOUTING.
joe
u naughty, naughty boy....i'll give u clip....round the eerol, if you SHOUT again.......
:lol: :lol: :lol: :wink:
As long as you don`t think the singular of premises is premise.......you can spell how you like.......and the ballvalve on the feed cistern in the loft is causing the noise :wink: as it replenishes the water that is drawn through the hot cylinder.That`s the most likely scenario
the miss's thinks i should go up to the loft when its day time 4 the day light !!! bless!
