As the arm of your float valve rises, you will see it presses against a valve shutting off the water.
Where this valve is, there is a large round nut that unscrews exposing the washer. Take this washer out and renew, or renew the whole valve if it does not cure the problem.
You will get a soaking if you do it live though so turn off your water.
