Noisy toilet flushing
27 Jul 2005
Leicester
Dear all,
When I flush my toilet lately I get a loud groaning noise within the floor as it fills back up. Is this water hammer?
Do I need to replace the diaphram/flapper valve.
Any ideas please?
Paul
Try the float valve washer first and then the float valve.
Will not be the flapper. :D
As the arm of your float valve rises, you will see it presses against a valve shutting off the water.
Where this valve is, there is a large round nut that unscrews exposing the washer. Take this washer out and renew, or renew the whole valve if it does not cure the problem.
You will get a soaking if you do it live though so turn off your water. :D
