Indeed it is, and I totally agree with you - but don't you think it's a pity that "they don't make them like wot they used to" - a lovely solid bit of brass with two screws per conductor (which used to be very standard for Wylex).Thats an old wylex board, personally i would look at updating that
How many fuseways are in the fuseboard? Even the old Wylex boards had an equal number of neutrals to correspond with the fuseways...
If you have a spare fuseway, you should have a spare neutral really...
A new CU would be a better option, and not too expensive in the scheme of things when considering adding an additional consumer unit to accomodate a shower.
...I also can't help but wonder where that very fat black-sheathed conductor connected to the right-hand two spaces in the neutral block is going (and ditto the second red of which we have a glance at the right of the piccie)!
As has been said, time for an electrician, I reckon.
Kind Regards, John.
I agree totally, but don't you think it's a great pity that you have to use that phrase ("a competant electrician")?Please, for the safety of you and yours, use a competant electrician.
Yeah... it's the best option... but hm.. Thank you very much!
No hm.. about it, that big fat cable in it looks like a heavy load already adding a shower will most likely exceed the rating of its main switch
Wheres Rf Lighting
