I had a Megaflow unvented cylinder fitted about 3 years ago. I have a problem regarding the non return valve in this system in that whenever hot or cold water is drawn off, the nrv slams shut with a loud thump like a hammer blow on the pipework. I have tried reducing the cold inlet feed pressure (with a prv) and reducing the draw off flow pressure (again using a prv) to no avail.
I previously had a similar unvented cylinder by Albion which, although using a prv on the cold feed, was silent in use for 15 years.
Advice would be appreciated please, thank you.
