I was having problems with nuisance tripping because my oven was on the downstairs ring main and not on a radial circuit. Every time we had the kettle, TV, oven and microwave on then it would overload. I decided to investigate as the CU has a radial circuit and it transpired that this was already wired to a socket and switch next to the oven. After a bit of work I was able to connect up the oven to this radial circuit and it's fine. The only problem is that I am getting nuisance tripping on the downstairs ring main all the time, even if it's just the kettle that's switched on. I've tested it a few times and the kettle and washing machine (independently) will both cause a trip. In my naivety I thought that removing the oven would have eliminated the tripping so why should it immediately have got a lot worse?
In anticipation!
Ian
In anticipation!
Ian
