oak shelving
13 Sep 2011
Hampshire
I am looking at building some simple oak book shelving inbetween two walls. Is oak 19mm thick going to be strong enough spanning just over a metre? I think I will secure it to the walls on three sides with 19mm thick battons along the full length.
Is this going to be strong enough to hold?
Thanks!
are they made from two or more "rotated boards"[grain up/grain down]
are they fully seasoned?
where have they been stored ??
I think its just a single board. I've not been able to find anywhere nearby which sells planed oak, where do you usually purchase from?
an oak plank that wide will be very unstable unless its well seasoned and stored well
generally wood needs to be around 2-4" strips alternating growth rings up and down for stability
in your case 5 bits off 2x1" planed comes out as 21x44mm so glued together gives you 220mm
