Here's a slightly odd one. I have just installed some outside lights controlled by a photocell. Having tested the system prior to 2nd fixing (ongoing building project), using a temporary supply, the lights came on OK but every time the photocell turned the lights off, the RCD in the CU tripped out. This even happened when I reconnected the temp supply from the existing house lighting circuit which is not even protected by the RCD in the CU!
The lights are 9W PL fittings, and I suspect this may be the root cause, as when I substituted them with ordinary lampholders with standard tungsten 60W lamps, all the system worked fine.
Any advice would satisfy my curiosity!
