Off-grid solar + wind in parallel?
7 Oct 2024
This not very (home) diy but.... I'm in a hobby club which needs 12v batteries charging in the clubhouse for equipment. We've no mains electricity, so use solar panels coupled with solar-suited chargers. With this recent 'nuclear winter' they're not getting charged much so I was wondering about having a wind turbine power source too.
Solar charging isn't something in my breadth of electronics experience, but I have gathered that solar panels and chargers - esp. MPPT - kinda interract with each other for operation/efficiency? So I don't know if a wind turbine can be simply Wire-OR'd into a charger supply, or does it need something intelligent...?
I played with solar panels in the 80s on the Falklands, which should with wind their been great, but it was rather disappointing. He got one propriety wind charger, and it was rated at 15 amp, but lucky if you got 3 amps.
I would ask about this on a narrow boat forum as they use them a lot.
What I have found the problem was hinged around was the charge rate of lead-acid compared with lithium batteries. You say 12 volts, so I assume lead acid?
For the faff involved the easiest option might be to just sling in a second battery and maybe solar panel to up the capacity. Have you worked out the power budget and how well it's matching up with the charging capacity? You might just need a bit more headroom.
Since the 90s things have moved on, the main change is the lithium battery. The main difference is the charge rate. In the main, a lithium battery with charge 2/3 of hour rate and discharge at the hour rate. But lead acid can discharge fast, but the charge rate is rather slow.
This was the graph from charging my car battery, and although when reasonably discharged it recharges well it drops off very fast.
