- Joined
- 21 Apr 2016
- Messages
- 43
- Reaction score
- 1
- Country
Good Evening,
I wish to replace the oil filter on my central heating system. Could someone advise me if a 10mm copper pipe can be directly connected to the oil filter, or will I need another connector? Will I be able to connect the oil filter directly to the fire valve using 10mm copper pipe?
I installed the system myself about 15 years ago. At that stage 3/8 inch copper was used to feel the oil from the tank to the system. The new replacement parts need 10mm pipe? Can I use a 10mm solder connector to connect the 3/8 inch pipe to the 10mm pipe?
Many thanks,
Jimmy
Many thanks,
Jimmy
