My heating is playing up, but it's a strange one...
hope someone can give some advice...
I have oil heating, where an oil tank feeds oil to a boiler, which in turn heats both the water and rediators in the house (it's a fairly modern system, and does these independently)
I have oil in the tank, the boiler does not need bled, and the water heating aspect of the system is working fine (for example, when I put the water heating to "boost" the boiler fires up and heats the water)
However, when the heating for the radiators comes on (when the light comes on in the control panel, either through the timer, or from hitting boost) the boiler does not fire up, and the radiators do not heat.
I've also checked the fuses, which are fine, so really cannot think what the problem is...
Anyone got any soloutions?
Also, for anyone who really knows their stuff - there is a temperature setting both on the boiler, and also one on the hot water tank in my airing cupboard - what temperature should these be set at - I've never been quite sure...
Thanks!
If you might be able to help, but have any questions, fire away, I'll be online for a while!
Thanks!
