Some advice please..
I am planning to put outside my back door a 2G IP56 waterproof socket, fed from a DG socket inside with an RCD wired plug and 1.5mm2 Artic cable (above ground, under deck).
I then want to use 6x50W GU10 spots set into the deck, daisychained from one of the exterior socket outlets. Same 1.5mm Artic used for wiring This is the bit I am not sure of - so many lights appear to be LV with transformer these days?
Is this assumption OK. Looks to be a standard CU for 1998 4 bed house if this helps.
