Hi guys,
I am renovating an old cow shed with old concrete into music rooms for working at home. I have removed the internal (non load bearing) walls which was a nightmare as the concrete may as well have been steel girders. With the times that are in it I just cannot afford to pour a new concrete floor which I know would be ideal.
My plan at the minute is to place wooden beams around the perimeter in two sections (so the two rooms I intend to put in there do not touch) and use 2x6 5.4m lengths to joist out the floor with a polythene barrier and insulation between the joists. There is currently no damp issues with the concrete floor that is there and there has been no moisture except for a leak in the roof which will be repaired.
As the room is approx 5.58m meters wide my spans won't be quite long enough to span the entire length, so I think I may have to construct a centre joist and join to that to break the length.
I am hoping to brace the roof from the external walls, so the floor will mainly be supporting the stud walling that goes into the rooms. I will use something like 18mm sterling board as a flooring on the joists. Obviously I will place noggins to add support between the joists and from the joists to the floor.
Am I OK in my thinking? By placing a level joist around the external walls I am avoiding all the rises and falls that the shed floor was designed with.
Thanks for any advice.
The approx dimensions are 14m x 5.58m
