OLD FASCIA REPLACED
20 Apr 2026
Hey everyone!
Quick question about house maintenance—back in May 2025 I bought a house in South England, but the state of the fascia was terrible (rotten boards, plus a nest in the under-roof).
I got it all replaced with new PVC fascia and new plastic felts. However, in April, a small piece at the end of the fascia fell out of place. The tradesman came back and fixed it, but with all this torrential rain lately, I'm a bit paranoid.
If there were a leak, would it be super clear and visible right away on that corner of the house in my bedroom or in my neighbours?
The fascia itself isn't what keeps the rain out. It's a board the gutter hangs on. The waterproofing at the eaves is the roof felt/membrane, which should run over the fascia and drop into the gutter (often over an eaves protection tray). A loose end piece of fascia is mostly a cosmetic and wind issue, not a leak by itself.
If there was a leak it wouldn't always be obvious straight away, so a few things are worth checking after heavy rain:
  • Go in the loft with a torch and look along the eaves: damp or dark staining on the rafter feet, wet insulation, or drips from the felt.
  • From outside, look for water running down the face of the fascia or behind the gutter instead of into it. That usually means the felt is short of the gutter or the gutter is set too low.
  • Look for staining, sagging or mould on the soffit boards underneath.
  • Check inside on bedroom ceilings near the outside walls, especially in the corners.
If all that stays dry through this weather, you're very likely fine. If the same piece keeps coming loose, ask the tradesman to fix it into the rafter ends with stainless screws or fascia nails rather than just the original fixings.
