Apologies for my ignorance but I have been using a fuse wired like this (Wylex 30A) for over 20 Years. Please explain to a novice why 30A + 15A fuse wire does not add up to 45A rated fuse wire?
A 9.5Kw Shower but 6mm2 cable and not 10mm2 the cable run from CU to shower is only about 7m.
9.5KW @ 230 Volts = 41.3 Amps. Volt drop using a 7 Metres run of 6mm2 T&E cable would be only 2.1 Volts (0.9%). What's wrong with using 6mm2 cable for a 9.5KW shower when the cable run is only 7 Metres long?
9.5KW @ 230 Volts = 41.3 Amps. Volt drop using a 7 Metres run of 6mm2 T&E cable would be only 2.1 Volts (0.9%). What's wrong with using 6mm2 cable for a 9.5KW shower when the cable run is only 7 Metres long?[/quote]
and what happens when he wants a more powerful shower next year?
