Old potterton will not ignite
23 Jan 2008
Warwickshire
Good morning all, i have an old potterton boiler (sorry dont no the modle there are no signs of it anywhere) and the piolt light is on but when i turn the thermostste up and put the timer on constant it does not fire up.
does pump work
If you have motorised valves, are they/it working
is there power to boiler
does it have an overheat
hi thanks for the quick response. yes the pump is working and my mate told me to listen the the silver valve and it makes a noise when i turn from hot water to heating
can you test for 240v coming in to boiler, also to gas valve when thermostat is turned up
then it may well be gas valve nakkered, corgi job touching those.
Just because your screwdriver lite up does not mean there is 240v. Make sure it is tested with a proper meter...Only trying to help
hi there is power there but before i mentined the 3 way valve was working but its not will this stop the boiler fireing
live goes clock-room stat-3way valve-boiler stat-gas valve so if you have 240v at gas valve it is faulty
