When I first moved into my
House I had a few problems with wet and dry rot due to poor air flor underneath my suspended timber flooring (downstairs) I had it all treated, new airblocks put in etc and it's been okay since,
I'm now looking to renovate my living room and as such will be pulling the floorboards up to retrofit insulation, the suspension underneath is approx 3 feet so no by no means small, I'm wondering if there would be any benefit down the line in rendering with waterproofs mixed in over the very old stone wall foundations or if there's an alternative method I could use to just make sure I make it as safe as possible,
I'm assuming when I pull it all up with the now adequate air blocks and the joists treated then the problem won't have come back but previously I had it all starting to climb up the walls etc and want to do everything I can to prevent?
Would a dpm to maybe the underside of joists be another option or something else you could advise??
The current plan is to lay insulation between joists, staple a Dpm sheet to that and then either relay floorboard or use p5 board before carpeting..
Thanks for any advice, novice on this subject
