Oli boiler will not fire up
5 May 2008
Monmouthshire
I have an oil boiler (Worcester Danesmoor 15/19), which I use for the heating (I use the electric for the hot water, due to cost) The boiler is in a cupboard in the kitchen, the programmer is situated in the airing cupboard upstairs and in the downstairs hall there is a dial thermostat (Drayton).
As the programmer was the old type i.e. dialled with either the choice of timed or on, I decided to purchase a programmable thermostat. I purchased one at B&Q, but when I got home I noticed it was battery operated, my thermostat has a label saying that ‘it needs to be connected to a 230 volt connection, otherwise you will not hear a click’ So I went back and was advised to purchase a ‘Sunvic TLX RFP’
I installed it today and it worked for about 10 minutes then the boiler went off. The thermostat is still calling for heat, but the power light is off on the boiler. I replaced the old thermostat and also switched the hot water to the boiler, but still nothing!!!!
Please can somebody offer any help, as my wife is now not speaking to me???
The instructions did give me the option to make the thermostat VOLT FREE, by removing a piece of wire, but as my old thermostat said it needed 230v I left it in, I hope this was right???
That is a very good question, but i hate the cold...
The fuse at the main house fuse box is ok, is there another one??
I'd check your oil tank first, ensure you have fuel, don't just rely on the fuel gauge, dip the tank.
Has your oil boiler 'locked out'?? Is the 'lock out' light glowing??
Is there a 240v supply at the 'switched live' at the boiler??
My wife is not speaking to me either, she got killed in a bad RTA last week, but I'm looking on the bright side, as I've coped £100K from the life insurance :D :D :D :twisted:
