on/off boiler light and clicking on baxi solo 3 pfl 60
18 Apr 2004
Hertfordshire
Hello.
Firstly thank you in advance. You are always really helpful.
So my boiler is clicking on and off. I've lifted the front panel off ONLY, and there are a series of lights.
The overheating light is OFF
everything else is on
The boiler light goes on and off constantly every 3 seconds. This matches the visible ignition in the pilot window.
Is this normal ?
What could be the problem is there is one ?
Yes, pretty normal , it happens every time the pcb fails!
But it could also be eg problems with the fan pressue switch/tubes etc. A corgi job - fan and burner pressures need testing too.
Some of these were supplied with a faulty batch of elbows on the aps that cracked causing these symptons.
