One pipe central heating
29 Jun 2006
Hello,
I may be converting a one pipe system to a two pipe system. How easy or difficult would it be to do this? All the floor coverings are going to be replaced so access to pipework is straight forward.
Will it be a case of removing all the existing pipework, and then running all the new pipework, and installing the pump and mid position valve?
Thanks for any advice.
:lol: you`re a card, Stan :wink: ...........and the rads may be wrong size too :cry: seeing as they`ll get more hot water in`em
All the rads will be new.
It's a reasonably new boiler, a baxi. My usual work is bathroom fitting, so I was just wanting some ideas on how straight forward it is to do this. Running the pipework, and fitting the rads is no problem, it's just the bits around the cylinder, valve, pump etc that i'm not 100% on. I'll have to do a bit more research.
Cheers for the help though :wink:
