Hi I wonder if anyone can help, I have a towel radiator in a new extension that will not heat up. I have cleaned it out, checked for air locks and checked that the valves function ok, when it refilled it heated up but does not heat up when the heating kicks back in.
When I checked the valves only one had water flowing, I assume this is correct as the other is a return?
All other rads new and old work ok and there is a rad on the opposite side of the wall and this functions ok so I do not think that the distance from the boiler is an issue.
The system is a condensing boiler with hot and cold tanks
Any help would be greatly appreciated as the origional plumber has stopped answering his mobile to me and I think my next step is knocking holes in new walls...
James
James
