Hello -
I've read through threads and haven't found the solution to my problem. Hope someone can help.
I have an Ariston EuroCombi A/23 MFFI.
I live in an area with radical limescale build-up and because of this, I had the secondary heat-exchanger replaced about 9 months ago - flow rate was so bad that the diverter wasn't being activated.
Now, nine months later, the flow rate is getting pretty bad again. I can't afford to shell out another £270 for another replacement so I decided to descale the exchanger myself. Everything has gone OK: heat exchanger removed, descaled and refitted and the flow rate is back up.
But, now the water doesn't heat up enough - with the thermostat set to max., I can easily put my hand into the running water - I guess around 45C.
The new flow rate is not particularly high, and it doesn't make any difference to the temp. if I stem the flow rate by closing the tap, so I don't think it's a flow rate problem.
Anybody have any ideas. Thanks in advance.
