I have a thermostat that is wired to an extractor fan. Id like to also add a humidistat controller as well to operate the fan.
If I wire them up in parraell fan will operate from the thermostat so there is power going to the fan but as soon as the humidistat goes live then there will be power also going to the fan at the same time which I think cant be good.
I thought having a switch/relay of some sort that knows which one is workling could be the answer because if I wire them up in series and the thermostat operates then the power wont get to switch the fan on if the humidistat is not operating.
I think one side needs to know what the other is doing so it can switch on/off accordingly
I hope someone can help and let me know how its possible to wire this up and also to point me in the direction of buying a switch/relay if necessary or if someone has a dual system already and wants to sell it let me know but it would appear that a dual system is not available, unless you know better?
