Opinions on Ecobase interlocking Shed base system
3 Feb 2009
Yorkshire
I'm looking for the most straight forward way of preparing an 8x6 shed base & I noticed these & wondered what you thought of the idea, as compared to the old way.....paved etc
Never heard of it but just been googling and it seems a decent alternative.
These folks - http://www.simplygardenbuildings.co.uk/ecobase-shed-base-foundation-599-deal-43-p.asp - do it for £6 per tile so at 20 tiles for an 8x6ft shed that's £120.
The alternative is to dig out and lay pea gravel, sand and slabs which is going to come to £60-£80 anyway. I might consider it for a second shed that I need to put in, in a couple of months.
Cheers!
edit: can get something similar for £95 (8x6ft) on amazon - dunno whether it's the same manufacturer, tho
They may be made from recycled plastic, but let's be honest they can hardly truthfully be called Eco friendly, mind you compared to concrete they are.
You can lay down cardboard over grass the full extent of the shed footing (suppresses growth) make sure the grounds level, lay the shed floor on some suitable size timber posts with strip dpc under them (ok not the most eco-friendly product) and once the shed is erected close the bottom gap to stop any light getting in. With the light blocked no plants can grow, grass turf dies back to an almost inert load bearing mat under these conditions, and unless your rolling in and out trucks or something will service for years to come...pinenot :)
I think it's the ease of use that apeals to me more than the Eco side of things. Less labour intensive.
Only on visible borders if you have a larger area. Not needed directly under shed (according to website) I've ordered mine
OK - fairy nuff.
I guess if it protrudes the gravel is (a) cosmetic and (b) to stop water splashing up.
