Options for replacing a toilet
11 Jan 2019
I want to fit a new toilet but the waste pipe is at 90 degrees to where the current toilet is.
Hopefully that can been see in the image.
Ideally I would like to rotate the toilet but there is only 87cm between the wall and the bath.
What would be the best solution for a toilet in this awkward space?
Thanks,
Sam
You could fit a frame hung toilet and concealed cistern ( as Hugh says) and do some boxing in to hide the soil pipe. OR if you've got another toilet, fit a urinal turned 90 degrees ( they do make them for domestic properties) Then have 1 toilet room for no.1's and one for no.2's:unsure:
Or move the pipe.
Is your soil stack inside or outside?
The stack is internal and I think it is cast.
Moving the waste pipe is the idea solution but I was hoping to for a simpler solution as I don't want to completely redo the bathroom.
Currently wondering if a corner toilet would fit in the space.
A corner toilet would put you even further away from the pipe.
Way I see it, you can fit another toilet in the same place but use one of the connectors shaped like a question mark or build a box in the corner and put a toilet on that.
