Hi
I've just about finished my double skin brick shed and I'm about to do the roof.
My plan is for a warm roof so I'm going to lay the 18mm OSB3, then a Vapour barrier followed by 100mm celotex insulation boards. I'm thinking about putting another layer of OSB on top of the insulation before I finally lay a single sheet EPDM on top.
Can I use OSB2 11mm just to cover the insulation and put the EPDM on top? I can get hold of some OSB2 for a lot less than OSB3 which is why I'm considering it. My local merchant only carries the 11mm OSB2 and 18mm OSB3 but i think the 18mm is overkill just for a covering of the insulation.
Can someone offer some advice please? I would imagine the OSB2 would be fine but I'm no expert.
Thank you..
Thank you..
