I've got a few questions I couldn't find answers to
1) for a high wall light by a back door where the cable will be run down to the light from within the soffit, does this still need to be SWA cable? Also I wanted to switch it from a normal 3 gang switch by the door which would ideally also be switching an internal light. Can I do this by running a seperate outside light power cable from an mcb?
2) I was planning to run power to my garage using two 2.5 twin and earth from an mcb terminating in a weather proof junction box on the wall outside then running SWA from there to the garage, having read a bit more on the forum this doesn't seem the normal way to do it, is it a 'bad' way or just unusual?
3) in a combination of the above, I was also hoping to have lights around/in my patio and hoped to run power to a normal switch (from a dedicated outside lighting mcb) and then the switched supply to the lights to another weatherproof box on the exterior of the house which I could at a later date connect whatever I chose to (again is this against regs, just bad practice or fine?)
I haven't talked these over with my electrician yet as he is on holiday but hoped to get the cables laid in by the time he got back so he can inspect and I can get the plasterer in, so any advice would be great..
thanks
Trev
(did search the forum but couldn't find anything simlar, thanks)
thanks
Trev
