Outlander washer pressure low
14 Jan 2008
Staffordshire
Morning all.
59 plate 2.0 litre diesel.
Both front windscreen jets barely clear the scuttle.
Bottle fully filled.
And doesn't appear to be leaking anywhere.
I'm guessing:
Pin to clear jets first.
Sounds deadening under bonnet off next, to check hoses.
Osf wheel arch off, to get to pump?
Any tips or how-tos gratefully received :-)
Grotty soap deposits at the pump end, I'd guess - the nozzles would appear to be clear so a pump restriction is most likely.
John :)
How do I get to the pump then, John?
I know little about cars!
And, once there, how to i remove said soap scum?
Is it as simple as dismantling the pump, and scrubbing / swilling it?
The pump lives at the bottom of the washer bottle and is usually a push fit......the bottle itself often lives under the wing, behind the wheel arch liner.
Sorry I can't be more specific about your vehicle!
John :)
