outlet pipe from expansion tank dripping (sealed system)
1 Apr 2004
The outlet pipe running from my red expansion tank in my sealed system to the outside suddenly started to drip. The pressure guage on the expansion tank was at 5 bars (not sure if this is correct or not). I tested the release valve on the outlet pipe and the pressure reduced (didn't want to reduce it too much since I don't know what the correct pressure should be. What would be causing this drip. Any ideas?
tom
You have a safety problem. The maximum pressure should only be 3 bar before the pressure relief valve goes. Your guage is incorrect or your pressure valve is faulty - either way you need to get this checked urgently.
Normal cold pressure should be around 1 bar.
