aegchambers said:
I believe I have a one gang, 2 way switch (i.e. two switches in a standard single box).
That's a 2-gang switch. 2-way means switching a light from 2 locations - e.g. the traditional landing-light scenario.
I have a new house with a hallway light and an outside light.
How new? New as in brand new and still under guarantee, or just new to you?
only two yellow / green wires are connected to the earth point (the other two are cut off).
That's not right - earth conductors should not be cut back. Hence my question about guarantee - if it is under guarantee, raise this as a fault - get it fixed FOC.
The neutrals have been connected via a terminal block that bypasses the switch mechanism. I'm left with four brown wires that are connected to 1 (common) and 2, 1 and 3 with a bridging wire between 2 and 3 (I believe, if i remember correctly).
Please don't say you disconnected the wires without making a note of what went where....
This was the standard connection that does not have the outside light wired in, but the wire must be one of those 4.
Which is it? Are all 4 brown conductors connected to switch terminals or not? If they are, and you are sure that one is the cable for the exterior light, then how does that square with "
The outside light wire is just hanging there, but has apparently not been connected to the switch"?
How many terminals does the switch have - 4 or 6? Are they labelled COM/L1/L2, or L1/L2/L3? Did both switch toggles do something, or did one do nothing? Is either one part of a 2-way switching circuit?
I've tried different combinations but as yet am unable to get both the hallway light working as normal witht the outside light on.
What do you mean by not as normal?
I also notice that the wiring method is also affecting whether I can turn my living room lights on.
Were the living room lights controlled by this switch before?
I'm struggling to figure out what wiring method has been used to connect everything, and what one I should use to get the hallway, outside and living room lights working as normal.
Would help to know what was normal, particularly regarding the relationship between the living room lights and this switch..
I'm sure its quite simple but I can't figure it out. *Any* help would be much appreciated especially some diagrams
. Thanks guys.
You've got neither of the traditional systems (junction box or loop-in ceiling rose), so the diagrams in the For Reference section will be of no help.
Don't suppose you have a multimeter?
