I've tried to fit an outside PiR security light by cutting into the lighting radial circuit but when connected it causes the cloakroom tube to flicker. I've taken a direct connection and not used a FCU in between is this the problem?
I'm beginning to think it must be, as I've now fitted a switched FCU (which does indeed make life easier for isolating the light!)Lectrician said:It's not a switch cable you have 'chopped' into is it??
pegasus said:Ref brown-nought's response.....
If an isolator were fitted alongside the PIR does it need to be double pole?
