Ive purchased 5 x IP65 downlighter fittings to install in the soffit area at the front of my house.
As they are the GU10 IP65 type i do not require a transformer which will make it easier to install. I would appreciate some recommendations or advice for the following:
- if i wanted to use a photocell to control when the downlighters go on or off (dusk / dawn setting) can anyone recommend a white coloured photocell to match my soffit. Would i then need a transformer if i was to us this?
- Bulbs: What bulbs would you use for outside lighting in a soffit? halogen or Led, cool white or warm white?
Appreciate your advice.
Thanks, Firstdmc
Thanks, Firstdmc
