    Dismiss Notice
Soffit lighting with Philips Hue GU10
Discussion in 'Electrics UK' started by Dave Grant, 1 Nov 2020.
  1. Dave Grant
    Dave Grant
    1 May 2020
    29
    Thanks Received:
    Cambridge
    Country:
    Hi all,
    Looking at buying soffit downlights for my new workshop (work in progress) and would like them to use the Philips Hue GU10 bulbs - think I'll only need two (or three?), soffit is 2.5 meters.
    These are the Downlight and here are the Bulbs
    I would like to know if the bulbs would be safe to use in this fitting mainly because it's going to be outside in the cold and damp.
    Dave
  2. Sponsored Links
  3. EFLImpudence
    EFLImpudence
    7 Jul 2010
    37,082
    Thanks Received:
    4,160
    Retired to:
    Country:
    Portugal
    I wouldn't think either is suitable for such a location but I suppose it depends how long you think they should last.
    What a ridiculous price for the bulbs; they are considerably cheaper elsewhere, although still expensive.
  4. chivers67
    chivers67
    18 Nov 2008
    1,408
    Thanks Received:
    172
    Surrey
    Country:
    Do they need to be a Mood Type Down light?
  5. seasickstevie
    seasickstevie
    14 Sep 2006
    1,568
    Thanks Received:
    84
    Liverpool
    Country:
    Why wouldn't the downlight fittings be suitable?
    They're described as galvanised soffit lights, guaranteed for 15 years.
  6. EFLImpudence
    EFLImpudence
    7 Jul 2010
    37,082
    Thanks Received:
    4,160
    Retired to:
    Country:
    Portugal
    I said I wouldn't think they would be suitable. I might be wrong.
    Not a soffit, no through passage of air, will be a very damp area.
  7. seasickstevie
    seasickstevie
    14 Sep 2006
    1,568
    Thanks Received:
    84
    Liverpool
    Country:
    Well it appears, the op Dave Grant is using his 'intuition' and wrapping the unit in breathable felt, so maybe the damp won't be too much of an issue.
    (see what I did there :))
  8. Sponsored Links
  9. flameport
    flameport
    10 Mar 2007
    9,817
    Thanks Received:
    1,962
    Poole, Dorset
    Country:
    As this workshop appears to be made from a steel container, it would be interesting to know what supply arrangements and earthing system will be used for it.
  10. Dave Grant
    Dave Grant
    1 May 2020
    29
    Thanks Received:
    Cambridge
    Country:
    Your comment is irrelevant, I've already posted a topic on this and a sparky has been out.
  11. Dave Grant
    Dave Grant
    1 May 2020
    29
    Thanks Received:
    Cambridge
    Country:
    @chivers67 I would rather it be "Mood Type" or the philips hue gu10 white ambiance as I already have Hue lighting - therefore I can turn on from inside via voice.
    Hang on, does anyone else make GU10 bulbs that work with Hue?
    Also I'm trying to find main lighting for workshop the works with Hue or a ZigBee rated light switch
  12. SpecialK
    SpecialK
    27 Sep 2010
    708
    Thanks Received:
    98
    Country:
    IKEA?
  13. Dave Grant
    Dave Grant
    1 May 2020
    29
    Thanks Received:
    Cambridge
    Country:
    @EFLImpudence and @seasickstevie
    Okay peeps technically this is not a soffit but for the purpose of this build/design I've called it a soffit and soffit lighting will be installed.
    The roof will be a warm roof, OSB3 board on top and filled with insulation - the OSB3 board will go over the over-hang, It will then have EPDM fitted the whole length - fascia boards will be Siberian Larch.
    So the Over-Hang is what I'm asking about, you know how the top will be covered and the bottom part will have Siberian Larch - so the gap will be empty.
    Your thoughts peeps?
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
