Oven door not closing
17 Nov 2011
Bradford
Hoping someone can help.
This is a Rangemaster Toledo Electric Oven
Door has stopped closing, the little pin thing just doesn't catch and lock anymore.
Any help much appreciated.
Before ordering the catch, worth checking whether it's actually the catch or the door dropping. If a hinge has worn or a hinge pin has worked loose, the door sags a few mm and the pin on the door just misses the catch, even though both are fine. Close it slowly and watch where the pin lands, if it's hitting low or to one side it's the hinges, not the catch.
If the pin goes straight in and nothing grips, then yes the catch and roller jj4091 linked is the likely culprit
Check your model number and see if this fits yours
Legend, ordered
