    Dismiss Notice
Overflow pipe dripping cold water from unvented system
Discussion in 'Plumbing and Central Heating' started by HarryUK, 12 Jan 2013.
  1. HarryUK
    HarryUK
    25 Feb 2012
    7
    Thanks Received:
    Shropshire
    Country:
    Hi
    I have a unvented system with a megaflo cylinder, over the last year I have noticed the outflow pipe dripping outside. British Gas have replace the cold water PRV and the temperature and pressure value. Each time this has solved the problem. However the water has recently started dripping again, and this time British Gas have said it is due to a faulty mixer letting cold water flow through the hot water system, and then out of the over flow pipe.
    We live in a three storey house with the cylinder on the middle floor, would the faulty mixer only be those above the cylinder i.e. on the top floor? If so I have a shower, basin and bath mixer. I'm trying to isolate the problem but its proving difficult, any advice? Is the diagnosis correct? We do live in a hard water area.
  2. Sponsored Links
  3. JohnD
    JohnD
    15 Nov 2005
    74,264
    Thanks Received:
    4,290
    Crossgates, Europe
    Country:
    Cook Islands
    the faulty mixer problem is not uncommon. It is most likely on a tap with ceramic discs and a joystick. Probably a shower.
    If you have service valves on your taps, turn each of them off for a day, one at a time, and see if the problem stops.
    Otherwise, run each of them, half heat, for long enough for the pipes to the mixer to get hot and cold. Then turn off. Feel the pipes after five minutes. The one that is letting by, there will be cold water travelling up the hot pipe and making it feel cold.
  4. HarryUK
    HarryUK
    25 Feb 2012
    7
    Thanks Received:
    Shropshire
    Country:
    Thanks for the tip
    Do you recommend doing this on all the mixer taps in the house, or just those above the cylinder on the top floor? I thought the water was dripping into the hot water system via gravity, or could it be coming from those below or on the same floor as the cylinder.
    I was also planning on removing the cartridge from the shower upstairs and cleaning to see if this stops the problem.
  5. JohnD
    JohnD
    15 Nov 2005
    74,264
    Thanks Received:
    4,290
    Crossgates, Europe
    Country:
    Cook Islands
    all of them
    the taps are connected by pipes at mains pressure, so it won't matter if they are above or below the cylinder.
    the cartidge is more likely worn than dirty.
  6. oph
    oph
    20 Jun 2010
    8,747
    Thanks Received:
    1,495
    Sussex
    Country:
    Anybody checked the baffles in the cylinder.
    Probobly needs re-charging
  7. Sponsored Links
  8. HarryUK
    HarryUK
    25 Feb 2012
    7
    Thanks Received:
    Shropshire
    Country:
    Yeah the air gap has been reset a couple of times so I'm ruling that out.
  9. Scotty69
    Scotty69
    1 Jan 2013
    16
    Thanks Received:
    West Midlands
    Country:
    Air gap has to be done at roughly every 6 months
  10. HarryUK
    HarryUK
    25 Feb 2012
    7
    Thanks Received:
    Shropshire
    Country:
    Air gap has been replenished today.
    I took the two shower cartridges out and cleaned each one before putting the back in, however this did not seem to work as the dripping continued after the water main was turned on.
    However I did notice that when replacing the en suite shower cartridge and despite really tightening all four screws, there was a small stream of water shooting out of the shower mixer when turned on - could this indicate a problem with the cartridge, which could be causing the dripping into the overflow?
  11. JohnD
    JohnD
    15 Nov 2005
    74,264
    Thanks Received:
    4,290
    Crossgates, Europe
    Country:
    Cook Islands
    have you tried any of that yet?
  12. HarryUK
    HarryUK
    25 Feb 2012
    7
    Thanks Received:
    Shropshire
    Country:
    Sorry forgot to mention, I don't have any isolating valves on the mixer taps, but ran each one as instructed and couldn't feel the hot water pipe getting cold, so I tried looking at the shower cartridges.
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
