Please can you help?
I have a cold water tank in my flat from which after a period of time (8hours +) water starts to run out of the overflow. If I flush the loo or turn the tap on it stops. Surely it can’t be the ball cock because it would do this as soon as the tank was full?
It happens mostly overnight when water is not being used so I assumed that it was some kind of pressure. A few years ago the thermostat on the heater overloaded and boiled the water so a new thermostat was put in which does not heat the water over 65 degrees. I don’t think this has failed because I cannot see evidence of overheated water etc.
This doesn’t happen every day. It has happened about three times over the past 2 weeks and prior to that the last time was when we all went away overnight, which was a couple of years ago. In the past I have also seen my bathroom taps drip at night but not in the daytime.
