I have noticed that my hot water header tank has been overflowing and venting down the side of my house - I'd like to stop this but can't for the life of me figure out why it's doing this!
Firstly, the header tank is situated in a utility cupboard upstairs as there isn't enough room in the loft (the house is a one-and-three-quarter storey house) so it's very difficult to get a look inside and I can't get the lid off, just lift it up enough to get my hand in.
I have let hot water out and held the float arm up - no water comes in so don't think that's the problem. The hot water cylinder is electrically heated so no extra water is getting in from a heating coil in the cylinder.
The header tank has a cold water in, a connection to the cylinder, a vent and a return loop from the hot water cylinder - could the temperature be set too high and causing this? It's only on 50-55c at present.
I do sometimes notice a hissing when the hot water is off, could the float not be reaching the top (and off) position? Why would it be doing this and how do I fix it? I can't get a look into the tank and have to do everything by feel.
Thanks, David
Thanks, David
