mcelroy said:
Glow worm spacesaver boiler overheat trips after about an hour. Hot water from (think its vent pipe) flowing into header tank in loft. Is this normal? Radiators never feel as hot as I think they should. Any ideas. Have I a blockage somewhere and do I need a power flush. Any ideas on price if this is required. Thank You
Sounds exactly like the problem I have.
I have a Glowworm "Ultimate fanned flue range", I believe it's
the '100-120FF' according to my useage instructions.
Problem is the same as mcelroy's..
I hear a boiling type sound in the loft directly above the airing
cupboard where the hot water storage tank is. Sounds like the
storage tank in the loft is boiling or something. Then the boiler
overheat clicks and shuts the system down.
Radiators are hot, but again, as mcelroy says, they don't feel
as hot as they should be. They are bled fairly regularly too.
I did open the bleed valve (I think it was) on the pump, but i'm
not sure if it's working ok. Any way to test this? It does seem
to be making the usual pump sounds and i can feel it working,
but it's very very hot to the touch when it's on - not sure if that's usual?
plumberoy01:
Is there any way to tell if it is the thermostatic control knob on
the boiler without replacing it
Thanks all.
