- Joined
- 28 Feb 2019
- Messages
- 45
- Reaction score
- 2
- Country
Guys,
Turned on Onvif, set the username up, checked the port no, default is 554, set the ip manually on the cameras, pointed the NVR at it and still doesn't see it, the two existing cams on the system are on a different ip range which looks like it was setup by the previous user, I have given the camera the next ip along and still doesn't see it, set the cams to dhcp as well, still doesn't see it.
The existing cams that are installed are set to dhcp, yet on the onyx box, I cannot see where the hell it is pulling the addresses from, only network options are for the box itself.
Gaz
Gaz
