Painting internal masonry
9 Nov 2009
Edinburgh
I've an enclosed porch around what used to be the front door. The old external cavity brick wall is now an internal wall so never sees rain.
Is masonry paint truly necessary, or will emulsion do just fine?
Masonry paint is thicker than emulsiona and has better covering power, so you should be able to paint a wall with less coats and less need to spot-in thin areas
