Hope someone can give me some advice I've so far not managed to find elsewhere in books or internet.
I'm currently going about installing a new solid wood front door.
Everything is going swimmingly so far, it's trimmed to fit the frame, all the cut-outs have been drilled and I've primed every inch of exposed surface, including inside the cut-outs. Paint has been selected and purchased, both basecoat and topcoat.
My question is, do I also need to put all basecoat and topcoats inside every single cut-out? I appreciate that for things like the letter flap this is necessary to maintain the style of the door, but in particular I'm thinking about cut-outs for the night-latch cylinder and also for the mortise lock.
It took quite a long time with the old chisel to get the mortise lock cut-out large enough to take the lock, and it's pretty tight in there. My concern is that by addition of a few more coats of paint it won't fit any more. Should I have made the cut-out intentionally have a couple of millimetres play for this purpose? If so, I guess I need to take some more off and re-prime that.
Similarly, do I put all coats behind hinges, etc.? If so, won't that make them slightly out of flush too?
Many thanks.
SurreyWill.
Many thanks.
SurreyWill.
