painting new plaster
17 May 2005
Bedfordshire
Hi
i have just had the bathroom ceiling re plasterboarded and skimmed
i have also had a couple of walls skimmed
How long do i have to wait before i can paint ?
do i need to seal the fresh plaster, and with what ?
or do i just slap emulsion on ?
SLAP? SLAP? SLAP??????
What is his word 'slap'????
'APPLY' my friend 'APPLY'......
Ok .... drying ....well it depends on the thinkness, on average and in good conditions about 2/3 days.
Just wait for it all to turn pale pink or grey....then give it a day or two after that.
don't whatever you do attempt to sand it until you have APPLIED the first coat.....this is called a 'mist coat' you can use any MATT emulsion for this but thin it out a little first, this 'primes' the surface, reduces suction and absorbs into the surface....the amount you thin it by depends on the type of emulsion....better quality ones need a little more water than cheap ones...as a rough guide id for for about 30% water
If you don't 'mist' the surface and try and do the job in two thick coats you will 1..waste paint......2....end up with a heavy texture......3...find it hard work!.....oh and over time....it will end up flaking off
Once this is done allow to dry for a couple of hours and then give the ceiling a light sanding to remove an nibs or plaster splashes..you can also fill any imperfections at this stage.
Sand any filler you may have had to APPLY then paint with two coats to finish...(id reccomend vinyl matt as silk can show up imperfections on a new surface badly)
Viola!
