I used a sulphuric acid based drain cleaner to clear a drain blockage. Unfortunately I got is over all over the walls and some ceiling tiles (stupidly I used a compressed air gun after laying down the acid and it shot it out of the trap!!!!)
I washed down the surface and painted it, however the acid still remained over the walls and it shows through the paint.
I then used a paint stripper to remove the new and original paint, washed it down thoroughly and repainted. Still the same problem!
Is there any primer or sealer that I could use to stop the acid from affecting the finish?
Hope someone can help
Jack
Jack
