Painting over fire damaged walls and wood work
8 May 2009
Sussex
What sealants do people recommend for sealing a door/frame etc before decorating.
There has been a bathroom fire with just smoke damage. I have read that if it is not sealed correctly the black could bleed through.
Also if a smoke damaged wall is plastered over, will the smoke bleed through the new plaster.
Just make sure you wash the soot off first..failing that give it a coat of zinseer bin primer.
Same goes for the wall..wash the soot off first..the stuff shouldnt bleed through.
