painting over limewashed kitchen units
19 Nov 2005
Bedfordshire
What are my options for this. The finish required is eggshell/satin. Is there any prep work to do on the doors to allow the paint to adhere. Thanks
Eggshell/satin paint or varnish?..are you talking pre factory finished Limed oak?
yes Zampa - factory finished limed oak(as customer buys the units). Sorry, I meant paint - not varnish.What exactly is the limewash?
Sorry I meant limed Oak..
You'll need to give em a good wash down then a rub down, use wet an dry paper, its softer and gets into all the moulded bits 360 grade should do
Then a coat of Dulux super grip primer or Zinseer
Thanks for help Zampa. I assume there are reasons to use the special primer? Would dulux trade quick drying primer / undercoat not be up to it ? Obviously not questioning your knowledge here - just curious !!
Not really..primers like that are designed for absorbent surfaces mostly
Melamine primer is another one you might want to try.
