Limewashing over existing limewashed wall
18 Aug 2011
I have a cellar which I wish to spruce up a little. The walls had some loose limewash, which I have rubbed with a metal brush to remove. Some sections I can see bare brick, and most of the walls still have a decent layer of limewash.
Can any one advise me on how to move forward here? Is it just a case of mix up some limewash (and if so - to what 'recipe') and keep painting layers over the existing work?
I've put a few pictures up here
http://www.flickr.com/photos/grimaldinho/6082585274/in/photostream
You can if you wish purchase lime paint which is available in several colours, if you want to go down the limewash route make sure it's slaked lime and no more than a couple of years old. Get yourself a builders bucket and add around 6" of water then slowly whilst stirring add your lime, you need to achieve a workable consistency then apply using a 4" brush, dont attempt to apply it two thickly or the wash will craze as it drys.
When you apply the wash it will offer a transparent look which will turn white when dry.
Dec
One thing I forgot to mention you say that you used a wire brush, this is never advisable when using water based systems as the particles of metal will rust on application. So go over it with a stiff bristle brush to remove them.
Dec
Thanks for the tips folks.
@Will using cheap emulsion over limewash impair the ability of the wall to breath?
@Dec - Thanks for the info re: limewash.
This thread relates to a former one called a damp victorian cellar in which case an emulsion paint will probably begin to fail within a Month.
Dec
Oh right. I remember now, the one that needs tanking.
Yep thats the one and tanking would be the best option, yet the op didn't seem to keen on this route and his main concern seemed to be breathability and the application of a lime wash will certainly give him that.
Dec
That's right folks. Tanking would be too expensive an option at this moment in time. As I can improve ventilation easily enough, I'd just like to recoat the walls. As I understand, tanking will involve membrane + concrete which would knacker the headroom without digging out.
Then to be honest applying the lime wash really would be your best option, as I recall you only wanted to brighten up the walls and offer breathabilty. Not only will the wash achieve this it will also keep alive that old victorian cellar.
Dec
