Trying to locate a place to purchase an offset pan connector. The soil pipe is 30mm lower than the pan outlet.
Now, the cistern is a high level type( which I now have installed on a side-wall thanks to the help from people on this forum), so I have some tolerance on how near/ far the pan can be away from the soil pipe.
The soil pipe is cast iron with internal measurement of 90mm. The pan has an external outlet of 104mm wide.
I have looked at McAlpine and Mulikwik fittings, but they are either 20mm or 40mm offset.
Should I be looking at flexi-pipes? I did not want to use one unless I had to.
