Part for old Everest door needed
22 Jan 2012
UK
Hi, I hope someone can help me identify this part from an Everest door that's about 20 years old?
There is one at top and bottom of the frame, where the shoot bolts go. As you can see they are worn out!
I cannot find them anywhere, any advice on where to look or their proper name?
Thanks!!
It seems I have exactly the same door and need exactly the same bit. I would be very interested to hear if you can source these as I thought I would need to make one.
For now mine is padded with washers to help seal the door and I swapped the top and bottom over also.
Good luck
Graeme
If you can't find the right part then I would have thought a local engineering workshop might be able to make one up for you. They look a simple enough part.
Thanks. I am hoping by posting here one of the door fitting guys will know what its called, then I can hopefully track down a ready made one!
