Hi
I am decorating a room and observed slight bends in the plasterboard around the windows. To investigate further, I removed a pieces of the affected areas with multiool and later discovered that the bends might be related to forcefully conforming against uneven studwork. The issue is that the plasterboard has a tinfoiled back and it's the wall exposed to the outside. My questions are:
1) if i can just patch it up with regular plasterboard or does it has to be VPL plasterboard?
2) Are there any concerns on discontinuing the tin foiled layer?
3) can I use a regular plasterboard of smaller depth and level it up with multifinish or easifill?
Thanks in advance
Thanks in advance
