Patio heater cracked glass
7 Dec 2007
Flintshire
We had the patio heater out one day last week and it must have been to close to the window. Its now made a slight crack up the left hand side.
Its single glazed unit and its got our company name in frosted glass over it. Im guessing its going to cost a lot to replace?
I'm wondering if you can get like a repair kit for small cracks. Like they do with the windscreens? Any ideas?
Its just a long shot but its a large window so we'd rather not have to replace the unit if we can...
if you have laminate glass which i hope so then you may be able to get a windscreen repair company to stop the run,using their repair method may not be able to remove crack but stop it getting worse and destroying your logo as if a small hole is drilled at the end of the run it will not be able to run any further but this method is not gauranteed and the risk is it will run further any way during an attempted repair. but hey what you got to loose. as the run will eventually go further by presure of cleaning changes in temp etc best of luck
